Not at all its very basic With the engine cold remove the lower rad hose and drain the coolant {this can be recycled by straining it with a fine screen {panty hose works fine]remove the top hose and loosen the rad mounts.Make shure the ign is off and remove the rad cooling fan and ac bolts [if fitted].remove the thermostat and flush the system with a regular garden hose until its clean.You should replace the thermostat with a new one [only a couple of bucks but a must do on an older car]
fit the new rad [tip last off -first thing on]and connect the hoses refill and top up your coolant.Start your car and allow to reach normal working [let it idle until the rad fan cuts in and out a few times and hey presto yoy saved yourself money and repaired your own vehicle [well done]
I must add that a thermostat on a 2004 Forenza costs about $85 and must be bought from the dealer, otherwise its as he said.
For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
