Hold the display button for 3 seconds and it should unlock the parental control.
I have a TS2050T manufactured in 2005. The other day something fell on the remote and I have the treaded blue screen with lock. Somehow the parental lock turned on.
Thankfully, I came to this website and someone suggested holding the display button on the remote down for 3 seconds. IT WORKED!! Thank you to jillfloydhan!
SOURCE: child lock has TV locked
Well after spending about 45 mins on hold and searching the internet for the last 2 days the resolution to this issue is to hold the display button down for 3 secs .... Yep thats it Hope this saves someone some time --Brian
OMG!! Thank you so much for your post! I have had the hardest time trying to fix the TV; pouring over the owner's manual, changing batteries, unplugging, etc. All to no avail. I can't thank you enough. (I'm realizing as I write this that I may be a little too invested in watching tv...)
SOURCE: locked tv
my time warner cable remote unlocked the red lock by just pushing the 'FAV' button
SOURCE: omni tv t8005nf locked tv
on the omni tv remote...press the button with a square and a + sign for a couple of seconds
SOURCE: my tv is locked blue screen with red lock box how do i unlock it
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off
Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
