My antenna does not go down anymore. It is supposed to go down when the radio is shut off or and when it is turned on it is supposed to come out
Do you still hear the antenna motor, as if it is trying to goo up & down as usual?
If so, then its likely your antenna is just sticking and needs some graphite lubricant. Ask for it at your local autoparts store..pretty simple to use.
If you don't hear the motor I'd suggest you check the fuses etc. If all is okay there it likely needs replaced.
