1992 GMC Jimmy Logo
Posted on Feb 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Torn cv boot, outer boot, drivers side, replace boot or whole half axle? Is it possible to just replace boot?
Anonymous
Level 2:
New Friend:
  • Expert 97 Answers
  • Posted on Feb 22, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
97
Questions
0
Helped
32252
Points
261
There or after market replacement boots that are split the length of the axie you cut off the old boot replace with new with out removing axle
page hardy
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 20, 2011
page hardy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
601
Points
I cnt find the good spthlit replacement boots anymore cv shafts are pretty cheap and much easier than pulling apart the shaft to replace while it's apart just replace the whole thing i used to use the split boots w/ little nuts and bolts the length of the boot but......... somebody figured out they worked and quit making them
2answers
Front end grinding,making rubbing noise,Hard clunking & grinding noises
check wheel bearings
check brake pads and rotors
I would go for failed wheel bearings
2answers
My front of my car vibrates like crazy everytime I accelerate and turn right but when I let off the has it stops
Sounds like maybe a busted motor mount or transmission mount, or a worn out cv drive axle.Look under the front of the car at the drive axles there is 4 rubber boots 2 on each axle inner boot and outer boot.See if one or more of the boots is torn or split.
2helpful
Im replacin the cv joints on passanger side and driver side how do i get the axle out of the transmission casing is ther a key behind the plate with the 4 bolts? my truck is a 99 isuzu rodeo LS 4wd
remove inner cv boot, just on inside edge is circlip which holds inner bearing joint into outer housing remove circlip and separate joint outer housing does not come out of front diff unless you drop or remove whole front diff assembly
will have to remove whole stub axle hub assembly to remove drive shaft from outer wheel stub axle (hub) assembly
3helpful
2answers
My granddaughter's 2000 Stratus makes a front end noise turning left but not right. Half shaft or CV joint?
I'd say constant velocity joint. It's been my experience that the offending side is usually opposite from the direction being turned. Turn the wheel to each extreme side and get a look at the c.v. boots. If it's ripped or torn it's a good indication that foreign material has entered it and caused excessive wear. If I've helped, please rate my assistance. Thank you and Happy Holidays.
2helpful
2answers
Cv joint but the plastic thang that go around it
One would have to remove the half shaft to service the cv joint properly.
2helpful
3answers
My 2003 chevy malibu makes a clicking noise when i turn right or left. What could that be?
A clicking noise heard especially while making a turn is most likely a CV (constant Velocity) drive axle(s) that is worn out, and if the CV boots are torn and dirt has been getting into the drive axle CV joint, then replace the CV drive axle assembly and do not have the drive axle re-built or re-booted, especially when you can purchase a complete new CV axle assembly for under $60.00 and here is a link to check one out.
http://www.familycar.com/store/item/Chevrolet_Malibu_Replacement_Axle-Assembly_1997_2003_ARBC507101.html
2answers
Where is the cv joint
Hello harborviewdo. My name is Roger and i will answer your question. Your vehicle has two drive axle half shafts. One on each side of the transmission. The out board side of each shaft is called the outer cv joint. Generally when they are bad you will find the outer boot is torn and has thrown the grease out. Should you need further help please just ask. Please rate the answer you received. This way I know it was helpful. Thank you for using Fix Ya. Roger
1helpful
2answers
Throws oil from drives side of engine
Broken/Bad CV boot? Check the boot for cracks/tears/etc.
Good luck, TD
3helpful
2answers
Mechanic says i need new front axles......
Usually once the boot is torn, dirt goes in, and all of the lubricant goes out. If you have been driving it this way, it will damage things faster. Normally you hear a "click" when turning out of a bad cv joint.It is a safer solution to just replace both, but of coarse, not cheaper.
How often to replace cv boots/cv joints/axle?
If something off the road tore the boot, yes but if it has not been tore long and you don't hear any clicking noises around corners, you can just replace the boot.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
