No. Your original remote doesn't need codes. It is UNIQUE and should cover all features of your device. If won't work with new batteries, it has some problem and you should claim your warranty rights to repair or change it.
If your ORIGINAL remote stopped working , check batteries, contacts, etc. you even might seek service but take note: oriiginal remote has no "codes". It's unique and specific for your MODEL. Universal controls might cover many features but they are never as complete as original and need code input for each model / brand
If it is the OE (original equipment) key fob, meaning if it is the alarm remote control that came with the original purchase of the car it should not need reprogramming. If it is an aftermarket alarm then it may need reprogramming, more information is required to answer the question.
This is a common issue and the most common problem is that the solder joints holding the battery in the proper location. If any of these are broken the remote will not function. It can be fixed with a little solder or if your uncomfortable with doing it yourself, take it to a computer repair store (they can fix it ONLY if you have a broken solder point).
Take the key fob to the closest auto parts store (aka. autozone, o'reilly's, advance) and near the counters they have a key fob testing equipment (FREE). If the remote is working a light will blink when you push the key fob button while close to the testing equipment. If the testing light shows that the fob is working but does NOT unlock your doors, it needs reprogrammed. If the testing light doesn't blink at all, repair or replacement of the key fob is indicated.
Hope this helps and good luck!
If you live in the US, you can call the Logitech Sales Line at 1-800-231-7717 to buy a new battery cover and battery.
If you're from somewhere else let me know and I will tell you how to get replacement parts.
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Unless the set has front panel menu buttons and the on-screen menu allows you to select the source, the answer is "no, you can't switch without the remote". If the original remote is really broken, you may be able to use an RCA-brand universal replacement that has an "input" or "source" button. Unless the original is physically damaged, before you toss it check the battery contacts inside. They sometimes get loose from handling the remote a lot and don't make good connections. Also make sure the new batteries are fresh and facing the right way.
