I had had this TV for about 11 months when a yellow spot about 10" in diameter apeared along with a diagonal line to the middle of the bottom of the screen and up to the middle. The yellow lines went away after a few days but the spot remains. The discoloration mostly shows up on white or light colored pictures. Is there anything I can do to fix or help make this problem less noticable.
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
SOURCE: Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
i have the 51 inch and it has a bright/blue spot about 10 inches in diameter on the rt hand side and I also have brightness on the lower outer edges.
same
We have a yellow spot as well. Shows up on light colored shots. Very evident while watching B&W films. When viewing darker shots, it shows up as a blue halo.
Our Sony Wega is about 2 years old. Digging out the warranty info and will contact Sony.
I have a Yellow "X" with a spot on the upper righ corner of my 60 inch grand wega. The TV was purchased in Feb. '05. Im not sure what to do about it.
