You can not sharpen these blades. To sharpen them, you would have to be able to remove each blade frm the plastic cartridge tht holds them. This type blades are manufactured in such a way that there is no way to take out each of the two individual blades without breaking the part that holds them.
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
