20 Most Recent
Norelco Bodygroom Men's Total Body Grooming System Questions & Answers
I have a Norelco,Body Groom.
OK, I am incredibly impatient, so I just figured out how to disassemble the bodygroom on my own. The button issue is fixed quite easily as there is no spring.
To disassemble, I simply removed the silver/gray side plates. Then put an instrument in the blue hole and torqued it a bit and the fittings popped out of place and the top released. I recommend using some sort of plastic tool so as not to mar up the casing. Then, the guts are fairly straightforward. The button is just a piece of rubber with a rubber knob on the bottom. When you push it, it simply pushes a really small button on the motor. When it gets stuck, I am guessing the rubber knob has somehow gotten stuck next to the motor button. After you take off the top cover of the motor, the button should be back to where it is supposed to be. Just put everything back together in reverse order.
That fixed mine! Good luck!
3/10/2014 12:41:31 PM •
Norelco...
Answered
on Mar 10, 2014
I had a Bodygroom and
Same thing happened to me so I took the thing apart and that's all it took. The compartment that contains the battery and chip had a vacuum built up that prevented the button from being depressed. Once I opened it and released the pressure the switch worked again.
7/5/2013 6:50:20 PM •
Norelco...
Answered
on Jul 05, 2013
The Philips Norelco Bodygroom BG2040, does this
Welcome to Fixya,
According to the manual of The Philips Norelco Bodygroom BG2040, use only the cord and charging stand that was provided. Also you just have to plug the adaptor into
120V AC outlet.
If you want to know more about your Philips Norelco Bodygroom BG2040, just click
here for the manual.
Hope this will help you and answered your question.
Thank you for using Fixya.
12/25/2012 6:55:55 AM •
Norelco...
Answered
on Dec 25, 2012
The screen over the blade head is damaged where do
Hi, Not sure if you've got the BG2020 model, but you can try the folks at electricshaver.com and see if the have a replacement in stock. Here's a link with the foil/screens for Norelco shavers shown, I believe that your's is at the bottom of the page listing.
http://www.electricshaverstore.com/get_list_143.htm
If you want to talk with them directly, give them a call at 1-888-476-1785 and proivde them with the model number of your particular shaver and they can get you the correct parts.
Hope you find this Very Helpful and best regards!
10/23/2009 6:03:15 PM •
Norelco...
Answered
on Oct 23, 2009
Norelco body groomer
I contacted norelco and they said I need to buy a new head every six months. Nice. They will send me one free. As I said to them, I doubt if I would sustain that buying habit.
2/18/2009 3:54:36 AM •
Norelco...
Answered
on Feb 18, 2009
