Compaq Presario 1200 Notebook Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the version of the usb port on a compaq presario 1200
  • Tina Nalty
    Tina Nalty May 11, 2010
    Could you clarify what you need to know the version for?
Tina Nalty
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 121 Answers
  • Posted on Feb 12, 2010
Tina Nalty
Expert
Level 2:
Passionate:
Answers
121
Questions
0
Helped
37922
Points
371
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
contratek
Level 2:
Scholar:
  • Expert 83 Answers
contratek
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
36888
Points
239
Right click My Computer and select manage
The Computer Management Windows Appears
expand the Universal serial bus controllers
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability. If it does not state ENHANCED next to the name it is a USB 1.0
Types of High Speed USB (USB 2.0) Host Controllers
  • Intel Enhanced
  • SiS Enhanced
  • VIA Enhanced
  • ALi Enhanced
  • Standard Enhanced
  • NEC Enhanced
If The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
electronic & computer repair& servicre
Level 3:
  • Compaq Master 12,061 Answers
Compaq Master
Level 3:
Answers
12061
Questions
0
Helped
4008235
Points
36390
1 Related Answer
Anonymous
  • 14 Answers
  • Posted on Aug 10, 2009
SOURCE: Compaq Presario 2500 USB Problem
go to control panel -device manager and see if you have all the latest drivers downloaded and if u dont then i would try and update them. if that doesnt work search up the specific driver u need online and download and install it.
I don't know if the computer has a usb port
If it's a Presaio 1200 series as you say in the topic title, then you're in bad luck.
That's a really old laptop and does NOT come with usb support.
Regards.
Compaq motherboard jumpers
Number of USB 2.0 Ports - 6 http://www.amazon.com/Compaq-Presario-Desktop-2-53-GHz-Pentium/dp/B00008LUOH shows there are 6- 2.0 USB ports see here.
1helpful
Where is my modem compaq presario 1200
Compaq presario 1200 its a laptop and modem is inbuilt. If your laptop is in warranty then get in touch with Compaq. Do not try to change modem as warranty will get void. So donot try this at home.
None of the USB ports on my Compaq Presario R
Hi there!
Have you tried checking your BIOS? Pls make sure that the on board USB setting are enabled...this should fall under the integrated peripherals...
Hope it helps!
Does a compaq presario 5000 support flash drives
Yes, it does.
The Compac Presario 5000 series have between 2 and 4 USB 1.1 Ports.
Note here that the ports are version 1.1, which is considerably slower that version 2.0.
USB 1.1: 12 MBits/second
USB 2.0: 480 MBits/second
Aside form the speed, they are both compatible with your computer.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
2helpful
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Broken USB Port compaq presario v5000
The hardware USB ports are identical for both versions. Only the software and hardware controller are different.
I suggest you use a temperature controlled soldering iron with a fine tip for this job.
You need to dismantle the laptop completelt to remove the motherboard from the plastic case. Take a note of where the screws come from because they may be different lengths. Don't apply excessive pressure on the plastic case else it will break, start from one side and work around each side, the plastic case has catches to hold the halves together.
Start by rmoving the hard drive, CD/DVD drive, battery etc.
1helpful
Usb ports for laptop
Depending on if it has type I or type II PCMCIA slots, you can get a PCMCIA cardbus USB adapter.
They are relatively cheap on Ebay - about 7 bucks.
Just make sure you get one that is the correct card type, and comes with Win98 drivers.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
