Ok, well shortly after the last post a YEAR ago my treadmill shows the error code E44 and will not run at all. this really sucks as I had only used this thing a few times. How can I fix this!Ok, well shortly after the last post a YEAR ago my treadmill shows the error code E44 and will not run at all. this really sucks as I had only used this thing a few times. How can I fix this!
You can't post conmments that contain an email address.
Please RUN the software calibration for easy diagnose, and troubleshooting and fix it. 2)However test the motor itsel, speed sensor test it for open, dirty, and clean it 3) Lube the elevation motor shaft, gear. 4) See the diagram attached.
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced. If you get pass to this point then proceed with the calibrating the incline and speed. Press either incline key and the incline will calibrate automatically. Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.Press the Stop key once and remove the safety key.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Unplug your unit, then remove motor shroud . Next step is to locate the motor control board and plug you unit in. Your board should light up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flickers that should tell us the speed sensor is working, if not it needs to be replaced , their maybe other issues, Unplug unit then find the red and black wire that connects the motor to board disconnect them used a simple DC power source like a 9v battery connect them to the motor leads and if the motor armature rotates then all problems point to the motor controll board.
I've definitely never seen "P4" on a Landice before so I'm not entirely sure on that one. The other issues seem like they might be associated with stuck keys on the console. It's a very common problem if you have it in a humid area and/or it gets sweat on it during the work out. Being that it's a Landice, you should have a part warranty on it. Have you contacted them?
