20 Most Recent Cardiozone 5 Hp 325 Lb Limit Breeze Elite Treadmill Questions & Answers
I need to move the
the console first and then the uprites that hold the console. that should be enough
3/8/2011 2:00:38 AM • Cardiozone 5 Hp... • Answered on Mar 08, 2011
I have a Proform 860, I moved it to another room
Hello. Check these items:
1. The outlet - plug something else into that same outlet to be sure you don't have a blown fuse or a kicked circuit breaker. 2. The treadmill key. Remember that your treadmill will not turn on with out the little magnetic key in place. 3. The switch on the treadmill near where the power cord goes into the machine.
Hopefully one of these will solve your problem. Regards, Joe
PS Kindly rate my answer as helpful. Thank you.
2/9/2010 8:16:10 PM • Cardiozone 5 Hp... • Answered on Feb 09, 2010
Cardiozone Elite Plus HR T treadmill and am getting an error E11
Hello again Having typed everything below the dotted lines for the last 30 minutes, I found this. It has a magnetic speed sensor on the pulley https://www.justanswer.com/fitness-equipment/2srkz-just-moved-cardiozone-elite-max-hr-treadmill.html ============================================== Here is the parts diagram and it shows no speed sensor and all parts are unavailable. https://www.fitnessrepairparts.com/equipment/Select/7631/CardioZone/CZE-Elite-Plus-HRT Parts Diagram closeup https://www.fitnessrepairparts.com/equipment/7631/diagrams/7403 That is contradicted here, but my view is that they are guessing because the parts diagram shows no sensor and if it was there and a part of the management system and expected to fail, it would be. There is a picture of of two sensors from Amazon and eBay, one is a Hall Effect Sensor, and the other is a Magnetic sensor. If it has them, you wouldn't be able to miss them and they would be connected to Part 17 - Controller. https://www.google.com/search?q=cardiozone+elite+plus+hr+t+treadmill+sensor+replacement Generic Treadmill Sensors Treadmill RPM Speed Sensor - Replacement for Pacemaster Bronze, Pro, Plus, Plus 2, Elite, & Select Treadmill $21.14 Amazon CA High Quality Treadmill Magnetic Sensor Speed Sensor For Running $12.89 eBay Free shipping ..
2/11/2024 11:51:39 PM • Cardiozone... • Answered on Feb 11, 2024
On my Cardiozone treadmill, I hit the Mode button by mistake (have never used it), now all I get is an E7 error message with the number 22 or 23 to the right of it.
Try pressing the Mode button again until the error message goes, or disconnect from the mains or remove batteries to reset. How do I fix E7 error on treadmill? E6 or E7
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. ...
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
https://www.google.com/search?q=cardiozone+treadmill+e7+error
2/27/2022 2:04:31 PM • Cardiozone... • Answered on Feb 27, 2022
2answers
I have a cardiozone sports foldaway treadmill the manual does not specify a type of oil to use. I need to oil the belt. Does anyone know if 3 and 1 oil will work?
Use a non alcohol based silicon spray or liquid. The WD40 brand make the 3 in 1 silicone spray and it’s good for all non waxed running belts. Just make sure you get the spray in the middle of the belt. (Underneath of course) watch a YouTube video if unsure.
1/3/2019 2:10:22 AM • Cardiozone... • Answered on Jan 03, 2019
2answers
Http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html Good luck.
Nice blog. Thanks for sharing this valuable information. <a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Chandigarh</a> <a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Mohali</a> <a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Panchkula</a> <a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Buy Treadmill in Chandigarh</a>
11/27/2018 12:12:48 PM • Cardiozone... • Answered on Nov 27, 2018
Speed increases dramatically when trying to increase slowly on CardioZone Fast Track Elite II
This could be cused by the the display cover you touch to control the functions pressing on the touch switch array just under it. Carefully remove this. it is held on by adhesive and see if the symptom goes away. If it does, look for any dents on the cover. I have worked with these type of switches for nearly 20 years and they can be problematic. The other possibility is the mechanical switches you use to increase/decrease speed or tilt. They plug in seperately and you can disconnect them to see if they are causing the problem.
12/29/2013 11:28:11 PM • Cardiozone... • Answered on Dec 29, 2013
0answers
Need a safety key
buy it from www. fitnessrepairparts.comGod bless you
10/2/2012 10:43:36 AM • Cardiozone... • Answered on Oct 02, 2012
My cardio zone club max hrt speeds up and inclines
When i turn in my Cardiozone Club Max Hrt. it starts showing SI 2.
1/21/2012 11:52:09 PM • Cardiozone... • Answered on Jan 21, 2012
I have two cardio zone
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
9/13/2011 9:18:41 PM • Cardiozone... • Answered on Sep 13, 2011
My treadmill belt just stopped, message error E
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
3/13/2010 3:06:10 AM • Cardiozone... • Answered on Mar 13, 2010
Cardiozone 5 Hp 325 Lb Limit  Breeze Elite Treadmill Logo
Popular Tags
5 questions posted
Top Cardiozone Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Ojo John...
Ojo John...
Level 1 Expert
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Cardiozone Exercise & Fitness
Most Popular Question
proform 860 moved another room
  • Exercise & Fitness
