#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
By the way, your wireless terminal needs to be activated through a wireless gateway that your processor allows and has certified. The wireless radio or SIM card has to have been registred with said gateway and appropriate wireless carrier. There's good reason to purchase from and use point of sale terminals supported by your merchant services provider. Mainly in that they will work and you can call for support.
