Hi don the error code is a system overload. There are a lot of things that could be causing this temperature short circuit. Inwould take the cover of the unit and see if you can visually see any maybe dust or debri on any condenser coils or fans. If you can't figure it out call an expert.
Here is a link to the manual for your system
http://www.supco.com/images/Seabreeze/New%20Material%202011/NEW%20MULTI-ZONE%20INSTALL%20MANUAL%2012-10.pdf
did you open both service valves? If it's 89 degrees F in your home you are WAY under charged, assuming you are using r410. what is the pressure when the machine cuts off?
check your filters and coils for blockages , both these codes are pressure related , if the filter is blocked the system will not create the desired environment for the refrigerant to work properly as it is directly related to increasing and decreasing temperature .
