SOURCE: Operating SystemMicrosoft Windows XP Professional
ok first u have to remove and ram and and clean
SOURCE: problem in hard disk
control panel
computer management
disk management
select the disk and iniatlize by right clicking.
SOURCE: hi, i own samsung syncmaster
We need to narrown down the causes first by trying this monitor with a good working PC to make sure it is not monitor problem, we do not want to open uip the monitor unless we have to. Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find, if it is monitor problem then please read below:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Acrobat can't run correctly if the system doesn't meet the following requirements:
