I would replace the inlet valve located in the back of the ref. Sounds like its not closing all the way could be gunked up with calcium or have a bad solenoid. Be sure to shut the water off to the unit before you unhook the valve. If you have low water pressure then you may want to replace your saddle valve at the same time. (thats the valve that taps into your actual water line in the basement or under the sink) This should correct the problem.
Let me know if this helps _MJ_
Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. Try the dispenser to see if it's just
drips after use.
SOURCE: Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
SOURCE: Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
