Computers & Internet Logo
Posted on Feb 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using an access 97 database and my payroll system didnt open, i linked the tables again and the payroll system opened but i have lost the data i have just input. Can i still recover the files?
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
  • Posted on Feb 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
0
Helped
10369
Points
123
I think the database property is read-only. or ur connection to the database is read-only. change it to read-write. the recently feeded data cannot be recovered as it didn't got saved.
3answers
How to fix error in database: microsoft office access has detected corruption in this file
Are you suffering from the problems of damaged, inaccessible or corrupt .mdb or .accdb database files? There are several unexpected reasons to corrupt these files like virus infection, software crash or malfunctioning, dirty shutdown of PC, corruption in storage drive and even more.In any one of these above mentioned cases, you can use Stellar Phoenix Access Recovery is considered to be a complete fix. It seamlessly repairs all the corrupt MDB and ACCDB files of MS Access database. It can address database problems from any issue that is caused because of software conflicts, hardware failure, and any problem in database design.
1helpful
6answers
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
I created a table using swing components but when i close the window the data enered are lost...how to get the data entered in the table ?or how to store?
hi dear,
the data you are entering stores in a temporay memory( ram in this case), which lost when you close your application.
> if you want to store your data so that you can again access it, you will have to store data in a DATABASE(by using jdbc) or in a file(simpler)
try this link
http://bytes.com/topic/java/answers/856588-saving-jtable-data
15helpful
7answers
Undelete records from access table
ou can try to use third party Access recovery utility to restore your lost and damaged data from .mdb files. For more details about this software:-
Access File Recovery
3helpful
3answers
Payroll system in DBMS. I don't know what data is to be taken.
Firstly you need to determine/state whether you are using a database application, such as Access, MtSQL or MS SQL and programming them to do create this application, or are you using a programming development tool such as Visual Studio, ASP.NET, PHP or the like, as the solution and guidance will be different for each.
In terms of the data design, you should store the data necessary to identify each employee uniquely and each data point per employee needed to calculate their payroll. You should then store the generic (applys to all employees) such as tax rates, in separate tables and call on it to calculate wages and other paystub data.
For instance, the employee first and last names and tax ID should be a sufficient unique identifier. Create a table for just employees, their names, tax ID, start date, schedule, pay rate, number of deductions, direct bank payment data, etc., and whatever else you decide you need for each employee. You can calculate their wages by multiplying their rate by their schedule and applying the appropriate tax rate and medical/witholding deductions as you go, so calculated data does not need to be stored and consume database space.
You'll likely need a separate table for common data such as tax rates, one for deductions/witholdings, one for holidays, one for vacation accrual rates, one for medical rates, etc. This data if common to employees does not need to be stored per individual, as that would cause redundant replication of data. If the employees are on an hourly rate, rather than a set salary/wage, then you'll need a table of worked hours per employee, akin to their timesheet data. If you use a timesheet/timecard, the entering and storing only the totals and keeping the physical timesheet for backup records should suffice.
Once you design and populate your database as suggested above, then it's a relatively-simple task of calculating the computed paystub data and storing the salient resulting datapoints for the record.
Consider a reporting application, such as Crystal Reports, for your printing needs, as its far easier to configure Crystal or similar product to format reports, paystubs, checks, etc., than coding these from scratch.
Hope this helps.
How to export table in ms access to excel
yes you can export your access data into excel, follow steps on how to export.
1. open your access database
2. open the table data you to export
3. under table data view click tools menu
4. select analyze
5. select ms excel
6. this will open your seleted access table in excel
hope this will help you..
Code for find the Ms access database size using visual basic
The way to get the database size is to point to the directory that the database is do a DIR statement with an output to a file as in DIR payroll.mdb>dbsize.txt and then read from the text file, the first field of the second line being the name (which you really don't need) then the size value of the database.
To import the text files using VB 8 use
'Imports System.Data.OleDb Dim conn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\path\filename.mdb") Dim cmd As New OleDbCommand("SELECT * INTO [import] FROM [Text;Database=d:\path;Hdr=No].[dbsize.txt]", conn) conn.Open() cmd.ExecuteNonQuery() conn.Close()
3answers
Access 2000 database won't compact and repair.
mchampion,
You are in luck. I had the same problem a while back. Most of the time you will not be able to compact and repair a database that has reached capacity, however, you can import the database into a new one. The first thing you are going to have to do is find a very large table in your database and copy it into a new one. Then, delete that table from your old database. Now, open another new database. Go to the file menu and choose import. Now you must find your database in the directory and click it. Now choose one of the given options (tables, queries, etc.). Then, Press control + a to select all items. Now hit okay and it will import all of the items from your old database from that section into the new one. You must do this for each section (tables, queries, etc.). When everything is imported (should take less than an hour), compact and repar the new database. This will give you additional space to work with. Now you can bring in the table that you copied into a new database earlier the same way (import). This should put you back in business.
I suggest creating a 2nd database for any other data you may want to add later. You can always make link tables and such in your old database in order to get the additional data and prevent crashing your old database.
Let me know if you need any additional help.
ArthurB
Grand Canyon Tech
Grand Canyon Tech
