This procedure involves you having access to another pc. If so, it should get you on the right direction. Make a folder and unzip the drivers into this folder. Borrow any win xp cd that you can obtain. Download a program from the internet called nlite. A google search will take you there. Install this program. With nlite you can create a bootable cd/dvd disc to replace your lost one. The program
will take the win xp setup files from your borrowed disc and integrate the drivers into the setup directory. You can even intregrate service packs into the setup. In the unattended settings you can insert the license key and all the user info.(ie: country, date, timezone, etc.) Nlite has a wizard so
even a novice pc user can follow thru with the creation. This disc will become your new one.
Finally check the following url to ensure you have the correct drivers downloaded.
http://www.acerpanam.com/flex/acer/bin/acer.htm#
