Question about Advent Netbook
Cant connect to wireless away from home
I can no longer connect to the wireless connection when away from home at university anymore yet connects to my wireless connection ok when im at home.
You have to manually connect to your University's wireless connection. Double 9maybe single) click the wireless icon bottom right screen and then untick the box for connect automatically under your home connection. Then double click on the wireless connection that you would like to connect to from the list of available wireless networks.
Posted on Feb 15, 2010
SOURCE:
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
I am wireless with a desktop. I bought a wireless laptop and notebook with a Dlink. I am trying to get it so I can use it away from home but can't get connected to the internet.
Remember that you cannot go longer than 50 yards or so in distance with wireless.Describe the problem in detail, is not clear.
Sep 05, 2008 | Computers & Internet
Belkin Wireless N+ router won't connect to the internet anymore.
Please check the range of that wireless router and also connectivity of the router.
Jan 18, 2010 | Belkin F5D9630-4A Wireless Router
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Bue
Apr 14, 2009 | Compaq Evo N600c Notebook
Cant connect to my wirelessmodem
Try running the cd that came with the router again, since you reinstalled windows, the configurations for the router have been lost. If this doesn't help let us know and we'll work on it from there.. good luck!
Mar 14, 2009 | Dell Dimension 3100 PC Desktop
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
My wireless network is no longer listed
Ok there needs to be a few diagnostics first.
Can you still connect to to router with a wired connection?
If so, can you veiw the settings for the wirless network,, and are they the same as before?
If you cant connect with a wired connection i'd probably say the router needs replacing.
Please let me know if you can connect with a wire and if you can access the wireless settings?
Jun 21, 2008 | Toshiba Satellite A105-S4004 Notebook
My laptop would not connect to wireless while I was away in a hotel
Open up you're network connections in you're notebook & run the wireless wizard. Search for you're home wireless network.
You should be able to connect to you're home. Remove any other networks you might find. While you're at it I suggest you setup security for you're home network with a password.
Let me know how it goes.
Mike
Apr 18, 2008 | Toshiba Satellite A215-S7462 Laptop
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Advent Netbook Logo
954 people viewed this question
Top Advent Computers & Internet Experts
Alun Cox
David Thompson
Level 1 Expert
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
