I plug My tv in and there is no sound and no picture. No blue screen. The touch panel on the front lights up and blinks 5 times. I replaced the lamp and it is still doing the same. Can anyone help me?
Same problem, blue lights flash five times. No picture, no sound. The manual says Lamp, but I've replaced it and it still does the same thing.
Many posts say it's the Light Engine.Same problem, blue lights flash five times. No picture, no sound. The manual says Lamp, but I've replaced it and it still does the same thing.
You can't post conmments that contain an email address.
May I know if the LED light at the front panel has a pattern offlashesor flashing continuouslyin green color.
Please check if you can access the "Self diagnostic screen" by following the steps below. - To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes2 times(blink, blink)pauseand then flash3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from. Note: the TV must be inshutdownnot switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Yes I should be able to help you figure it out. First look on the rear of the set to check what the chassis number is. Should be an ATC 336 but it might be a ATC323 let me know the chassis number and we can go from there on diagnosing the problem
