At the rear of the motor shaft it will be squared off. if you can get a wrench on this and then use a impeller wrench or water pump pliers you can probally break it free. You need to check in the center of the impeller for a set screw. (not on all model pumps) This will be aleft handed screw so to remove it you will have to turn it clockwise. If need be you can put a screwdriver in a fin of the impeller and give it a sharp hit with a hammer to break it free. Once your done and reassembling the pump be sure to only hand tighten the impeller. Good luck.
SOURCE: the impeller will not unscrew from the shaft. 20
Try soaking it overnight with blaster, the stuff works great, Take off the back cover, you should have two flats on the shaft to fit a wrench, If it won't go left, try right and see what happens.
