Check to see if the Oil sender swith, Is Leaking.
Is it coming FROM the oil filter? you can tighten up the filter by hand, turn it clockwise as tight as possible by hand, use a cloth to help grip it, if it still leaks just fit a new oil filter - they come with a new rubber seal on them so will solve the problem - remember to clean up the surfaces the filter sits on , if they are left dirty it may still leak... ----------- If it is leaking from a crack in the engine then i'd need to see the extent of the damage before advice can be given. a little crack can be repaired with strong heat-resistant chemical filler and a drill, but a long crack is probably terminal for the engine block...
