Commercial descalers like CLR are about the worst thing you can use on equipment used to prepare foods. I would suggest nothing but food grade white vinegar.
Put it through a brew several times with white vinegar and let it sit for several hours. Come back later and give it a good flush with filtered or distilled water.
Use some descaler in it but flush it out well when done
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
