Dymo LabelPOINT 100 Thermal Printer Logo
Posted on Jan 21, 2010
Hi I'm wondering if the Dymo pocket will take a tape, so that I can iron labels on to clothing or even be stitched on. If so what would the cassette be called. Thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 06, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
28066
Points
19
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Enlarge font dymo handheld labeler
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see dymo.com for numbers).
^CM
Need instuctions for dymo label point 250
[email protected]. My manual is 12 pages long. Please put DYMO Manual as the subject and I will email it to you right away. Waiting for your response.
About Your New Labelmaker. With your new DYMO LabelPOINT™ 250
labelmaker, you can create a wide variety of high quality, self-adhesive labels. You can choose to
print your labels in many different sizes and styles. The labelmaker uses DYMO D1 tape cassettes in
widths of 6 mm (1/4"), 9 mm (3/8"), and 12 mm (1/2"). Tape cassettes are also available in a wide
range of colors.
Getting Started
Follow the instructions in this section to print your first label.
Connecting the Power
The labelmaker is powered by standard batteries or an AC power adapter. To save power, the
labelmaker will automatically turn off after two minutes of inactivity.
Inserting the Batteries
The labelmaker uses six 1,5V AA batteries.
To insert the batteries
1. Remove the battery compartment cover. See
Figure 2.
4helpful
My dymo letratag prints only bottom half of a name
Your cassette tape has probably become unthread. Take the cassette out of your handheld printer. Make sure that the tape is fed under both claws on each side of the tape. If the tape is only under one claw, your label will not be flat and will only print the bottom half of the letter on your label.
4helpful
Changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
3helpful
Dymo lextra tag xr
I was able to find the following error codes, however I realize they are for the Lextra tag QX50. I was unable to find codes for the Xr, so I e-mailed Dymo and will post a comment on this as soon as they get back to me.
For now, here are the QX50 codes, just in case they help:
LetraTag QX50 Error Codes trnsp.gif Question An error is dispalyed on screen when I attempt to print a label with my LetraTag QX50. How can I resolve this?
trnsp.gif Answer Error
Solution
Error 1
(Tape jammed or low battery)
  • Replace the cassette
  • Replace batteries
Error 2
(Big Font cannot be selected with characters in memory)
  • Select another font size
  • Select Big Font before entering text
Error 3
(Big Font cannot be selected with: box, underline, 2 line, or lower case)
  • Select another style format
Error 4
(Memory buffer is full)
  • Delete some of the entered text
Error 5
(Text is bigger than defined length)
  • Specify a longer tape length
Error 6
(2 line cannot be selected with the format)
Won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
2answers
Printing
I was having the exact same problem & had lost my user's manual (you can go on the Dymo.com website to download a replacement). The !!!!!!!!!! display means that there probably is a tape jam. Here's what the manual says:
*!!!!!!in the display indicates that the tape can not be transported *Press any key to return to normal display *Check if there is a tape jam. In that case, life out the cassette and carefully release jammed tape. Cut off excess tape and refit/replace the cassette *If there is no tape jam replace the batteries
Top Dymo Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
