I have a mr814 router that for some reason packed up and I could access the internet. I did a factory reset and now I can get on the internet but it didnt give me NG default ip address. I can't access the control panel to set it up. The other strange thing is my default gateway is different to my ip address (first 3 parts of course). gateway is 82.38.104 and ip starts with 82.38.106
Any ideas as to what I can do.
I guess u have static ip, on wan, on lan ur ips must be 192.168.0.1 for gateway, and 192.168.0.xxx for clients,and u must set a broadcats name.
I have the same problem as ggomez. Anyone has found a solution>
I have found my own solution to this problem. A cheap Lynksys wireless. I have found that it is fruitless trying to talk to netgear or Apple reps, one never gets to talk to someone really knowledgeable, and it is too frustrating having to step through their scripted questionaire. In addition there are a lot of well-intentioned people that can send you in a wild chase. No worth the waste of time when a $40 or less Lynsys would solve the problem. Good luck to the ones who still have the problem and still want to pursue a solution. Thank you to those who tried to help.
SOURCE: Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
SOURCE: I am trying to connect
The router including the Wi-Fi is system agnostic, so yes of course you can connect your Vista machine, or your Mac, or your Solaris, or your Linux or anything else. Just so long as your system supports the Wi-Fi card which is installed in it.
The great thing is that both the ethernet and the Wi-Fi are simply standard any system uses these systems.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
hope this helps
The wireless part of my MR814 does not seem to work properly. There is no problem accessing the internet via the wire connect. All lights are green. I have the latest firmware version - 4.14 RC4 Dec 11 2003 - according to Netgear's website. Security is open, encryption is disabled. Access list is off. All other settings are set to default. I have tried reverting to factory default settings, but the problem still persist.
I have an IMAC (intel) running MAC OSX 10.4.11 - a Toshiba laptop running Windows XP SP2, and an HP running VISTA. They are all within 30 feet of each other.
The router shows that the Imac as attached devices at 192.168.0.2 and 3, each with a different MAC address and the IMAC shows that I am connected to the router both wireless and ethernet. The IMAC is the only one wired to one of the 4 ports and the wireless adapter turned on. The other two computers have the wireless ON but are not acknowledged by the router nor do they receive the broadcast signal. These computers have been tested with other wireless devices from Netgear and they work properly.
Since the IMAC is the only one recognized by the wireless router, I turned the other PCs off and attempted to establish a good communication between the IMAC and the MR814 via wireless, but as soon as I disconnect the ethernet wire the responses are stopped and I can not access any website. The IMAC is still finding the SSID from the router, the network status in the IMAC still shows that I am connected to the MR814.
my connection isPPPoE how can i connect this router to my ip?
can't access the router config too unlock firewalls for gameing purposes
