I believe you're referring to the AOpen MX46-533V
The Front Panel USB header is Blue in color, and located in-between the white No.3 PCI expansion slot, and bottom edge of the motherboard;
http://www.ebay.com/itm/AOpen-Model-MX46-533V-Socket-478-Desktop-System-Motherboard-/130774572519?pt=Motherboards&hash=item1e72c59de7
With the motherboard in the installed position;
5 pins across the Top row, 4 pins across the Bottom row.
Pins across the Top row are numbered EVEN
Pins across the Bottom row are numbered ODD
Starting on the Left side coming across to the Right, Top row;
Pins 2, 4, 6, 8, and 10
Bottom row;
Pins 1, 3, 5, and 7
There are TWO USB connectors supported off of this USB front panel header.
For one of the USB front panel connectors;
A) Pin 1 is USB PWR 0
Goes to the VCC contact pin on the USB connector.
B) Pin 3 is USB_FP_P0-
Goes to the D- pin on the USB connector.
(Data - )
C) Pin 5 is USB_FP_P0+
Goes to the D+ pin on the USB connector
(Data +)
D) Pin 7 is Ground (GND)
Goes to the Ground (GND) pin on the USB connector
E) No pin 9
F) Pin 2 is USB PWR 0
For the other Front Panel USB connector;
A) Pin 2 is USB PWR 0
Goes to the VCC pin on the USB connector
B) Pin 4 is USB_FP_P1-
C) Pin 6 is USB FP P1+
D) Pin 8 is GND
E) Pin 8 is USB_FP_OC0
Leave unconnected
This is more information on a standard USB connector pinout,
http://en.wikipedia.org/wiki/USB( A USB connector, and a USB plug are not wired the same.
The plug is wired backwards from what a connector is.
Otherwise you would have power and signal going to the wrong pins, and burn the USB Front Panel header out on the motherboard )
AOpen MX46-533V motherboard manual, but it is in Japanese.
May be one in English out there.
The Front Panel header pinout, USB header pinout, etc, is easily cross identified,
http://global.aopen.com/products_download.aspx?sDropDownProd=52Manual / Japanese manual for MX46533V / Japanese / 1/28/2006
Go to the far right, and click on the Floppy Drive icon above -
3701.1 KB
On the next page click on the mirror server website that is closest to your country.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the country server name it may take up to 30 seconds, before the first page comes up.
(File is downloading in background)
For additional questions please post in a Comment.
Regards,
joecoolvette
