20 Most Recent Matsonic MS9158EP (DSMTSMS9158EP) Motherboard Questions & Answers
plz mother board matsonic ms9158ep sound driver free down load
Matsonic... | Answered on Aug 03, 2015
http://www.chung-sim.com/matsonic.ms9138d.html
Matsonic... | Answered on May 23, 2014
please give me lenovo sl400 bios reset password thanks
Matsonic... | Answered on May 13, 2014
which number ?
Matsonic... | Answered on Aug 25, 2011
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
http://download.cnet.com/jetway-motherboard-driver/3000-2098_4-163033.html
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html
these driver packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Matsonic... | Answered on Jul 31, 2011
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Its hard to find your drivers in google.
1st download and try to install these.
http://www.mediafire.com/?9qcuwdwcbcml2vi
the link above is a lan driver.try if it will work with your motherboard.
then try to access the internet. Once you have access to the internet, download this software
http://www.mediafire.com/?hwh6v0yymmrsho8
After downloading this software, extract and install it.
If your asked for the serial key, you will find it in the extracted folder. The name is Key.bmp
after entering the Key, Start Scan then after scanning. download the drivers of your motherboard.
Goodluck.
Please give me update if my solution worked. thanks.
Matsonic... | Answered on Jun 28, 2011
Here's a link to what I have found so far
http://www.matsonic.com/index.phpYou'll have to click the "View more" link for your respective socket to find the manual specific to your mobo model.
Matsonic... | Answered on Mar 24, 2011
please help me seach manual for motherboard matsonic ms9158ep
Matsonic... | Answered on Feb 06, 2011
dude....just google with this "MOtherborad name followed by drivers"...u wil get it..
Matsonic... | Answered on Jan 21, 2011
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Matsonic... | Answered on Dec 07, 2010
Each of the ends of the cables that lead to the LEDs should be labelled, e.g., 'PWR/power', 'RST/reset', 'SPK/speaker', 'HDLED/hard-drive-LED', 'PWRLED/power-LED'.
Connect each labelled connector to the labelled pins on the motherboard.
Matsonic... | Answered on May 29, 2010
no o9r faulty monitor
please ratEmy help+++++Thanks for using FIXYA
Matsonic... | Answered on May 20, 2010
how to install ms9158e+audio drivear
Matsonic... | Answered on Apr 10, 2010
son du carte mère matsonic ms9158ep
Matsonic... | Answered on Mar 09, 2010
we give power to fan from mother there there3/4 pin squiri white potr.we give power to bordfrom smps 9/12 white squite connecter.we join power/ led/ reset /usb cable between casing and mother bord. we can see this thing written in motherbord and wire connecter(small)
Matsonic... | Answered on Oct 31, 2009
I have a trouble with my PC. Please send me the software motherboard by my mail to update the system device. Thank You
Matsonic... | Answered on Oct 25, 2009
I guess there is problem with drivers my be they are not properly installed.. For this Go to Control Panel ---> System ---> Hardware ---> Device Manager if you have any device marked with a question mark or yellow admiration. See also Device Sound, video and games, to see if the driver is installed.
if you got a Software CD with your system then it should have the
Audio Drivers. Just Reinstall it.
I hope it will help.
Thanks
Matsonic... | Answered on Sep 25, 2009
hi follow this link and then your driver will be downloaded
http://www.userdrivers.com/url.php?link=aHR0cDovL2Rvd25sb2FkbWlycm9yLmludGVsLmNvbS8xMDQxNi9lbmcvQVVEX0FMTE9TXzUuMTAuMDAuNjA0MF9QVl9SRUFMVEVLLkVYRQ%3D%3D
Matsonic... | Answered on Aug 01, 2009
according to the manufacturer:
Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~3.06GHz or faster Processor
Support Intel(R) Hyper-Threading Technology CPU
400/533MHz system interface speed
any socket 478 processor with a 400 or 533 bus speed should work.
Matsonic... | Answered on Jul 23, 2009
Computers & Internet Logo
41 questions posted
Top Matsonic Computers & Internet Experts
Ram kundu
Ram kundu
Ekse
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Matsonic Computers & Internet
Most Popular Question
reset bios password
  • Computers & Internet
