SOURCE: how do i unlock the
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV
1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
SOURCE: problem getting panel lock unlocked on combi tv
need to turn volume up but panel lock wont let me and i have have no manual
Does anyone know the program code to connect RCA DTA800 to Trutech T2000-D??
panal lock
Samsung TI-14P1 TVCR
I NEED PANAL LOCK CODE I DONT HAVE REMOTE
