Sounds like an ignition problem. The fan is supposed to start first to get the airflow going, then the igniter should heat up (glow igniters) or start sparking (spark plug igniters), then the fuel starts pumping. If the igniter is not working the fuel won't start. Things to check.... igniter - see if it is intact, fuse (usually in the circuit board), If those are ok, then check fuel pump, fuel filter, air filter. Hope this helps.
