Email me from your Email I will send you a good softwere or let me know how to send you the softwere id you don't like to give me your own Email
2- I think it's better to creat a new Email and Ask me the Same way you writ
[email protected]
hi
i lost my files in my flash and appear usbc file , plz you send your software for me , thx.
[email protected],
hi i lost my files in my flash and appear usbc file , plz you send your software for me ,[email protected],
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F: D: or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.?
click start click on my computer to open you should see your drive
another way:
click start all programs accessories open windows explorer click on my computer you should see your drive click to open it also right click select send to desktop to make shortcut
click start click on my computer you should see your 4 GB data it might be listed as a mass storage device
right click then select format
another way is to control panel administrive tools computer management disk management right click on your -GB data traveller select format
if you need more help with this post a reply
hope this helps you
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click permissions
hope this helps
don
