The Screen isnt responding, i played with the calibration settings and now i cant get to where i want to on the screen. I need to calibrate it again but i cant get there cause the screen dosent allow me to open settings as its not calibrated open the file when i click on it.
Iv done that and its still not working. I keep reseting it but it still wont respond. thanks though.Iv done that and its still not working. I keep reseting it but it still wont respond. thanks though.
There
are two major reasons that could be causing the touch screen not to be
responding. The first is if the phone fell and the sensor board got bad,
and the best solution is to replace the sensor board. To replace the
sensor board is quite sensitive so i will strongly advice you seek
advice from a specialist that can assist you with that. But if you
intend to fix it DIY way, then you can ask and i will direct you through
the steps.
On the other, it might be the screen is weak and
needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to
calibrate the screen of your phone. If you cannot get any response from
the screen, i will advice you replace the sensor board. Because
calibration requires you to touch the screen and since it is not
responding to touch, it will be pointless trying to calibrate.
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
you need to calibrate your screen... go to your settings and find your touch screen settings. there should be a place to calibrate your screen from there.
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
I have the same problem I need help with this!!!!! >:(
