Toshiba SD R6012 (SDR6012-TA) DVD-RW Burner Logo
Posted on Feb 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba DVD-ROM SD 6012
My CD/DVD writer should burn CD's and DVD's. It burns CD's fine but will not burn DVD's. According to Toshiba this is a known problem and they say it can be fixed by downloading a new driver. I did that but the file will not execute. When i try it says "could not be found CD - Drive for this programme".
I also found through another forum that you need to alter the settings for the device to switch from CD to DVD. I did that but there was no effect at all.
Any help welcome.
Howard G
  • MBono Feb 14, 2008
    The drive will not recognize blank dvds. I've tried removing and reimstalling different software (roxio, Nero) to alleviate to no avail
Anonymous
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on Feb 05, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
207
Questions
0
Helped
60643
Points
460
Im sorry to tell you this my friend.. it seems I catch you a bad time but I suggest that you need to replace it with a new drive since CD/DVD writers has its life span limit.. Be careful in doing burn CD's especially if its in long hours since it tend to damage the lens of your drive because of too much heat that was prolonged in a long run.. If your'e using it as DVD ROM at the same time, I suggest that you must have another drive to minimize damage to your drives..
vr24cod
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 107 Answers
  • Posted on Apr 03, 2008
vr24cod
Expert
Level 2:
New Friend:
Night Owl:
Answers
107
Questions
0
Helped
32041
Points
286
Be sure you are using dvd-rw not dvd+rw. This drive will not write or read +.
Toshiba SD-R2312 Upgrade to DVD Writer
If your current device is CD-RW/DVD-ROM, then any CD-RW/DVD-RW device that you can purchase will _physically_ replace and will fit into the space occupied by your current device.
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
2answers
Unable to burn dvd using LG DVD ROM
your DVD Rom drive cannot burn DVDs because it is not a DVD burner, DVD Rom drives are different from DVD writers, if you want to burn DVD you must buy a DVD burner/writer.
2answers
Toshiba odd dvd sd ,wont rewrite dvds
Are you sure your drive is a dvd writer? And if it is a writer, is it a dvd -r or a dvd +r or a dvd -r/+r? Depending on the way the dvd writes to the disk, you will need to buy specific media for the writer to write to. DVD -R cannot write to DVD +R and vice versa, and even if the drive is a DVD -R/+R, they seldom write to both media with any degree of regularity or of good quality. Most dual dvd writers seem to prefer DVD -R.
Oh yeah, one other thing, if your dvd is a writer, you should check out the drive properties in my computer to verify it is set to record. If you see the recording tab, select it and verify that the box is checked to enable cd recording on this device.
2answers
Toshiba SD R2132 CD-RW/DVD ROM
Your CD "Burn" laser or "Quadrant Detector" has "Faulted" a very common occurrence for these "Combo" drives,...So..I'm sorry but ya gonna haveta get another... as these ya can't fix. :(
2answers
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
