2005 Jeep Liberty Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the correct torque for spark plug installation?
Anonymous
Level 3:
  • Jeep Master 6,982 Answers
  • Posted on Jan 03, 2010
Anonymous
Jeep Master
Level 3:
Answers
6982
Questions
0
Helped
2649957
Points
22782
Plug torque is not critical. Best way to tighten them is to run them in finger tight to make sure the they are not cross threaded, then tighten enough that you feel the gasket crush. (plug bottomed and just a bit more).
It is essential that you use anti-seize compound on the threads. That will prevent the plugs from seizing into the heads and snapping or tearing the threads out when removing the next time.
1helpful
3answers
I have a 2000 Volkswagen Beetle 2.0 5 speed the number 2 cylinder keeps blowing the spark plug out of the hole what would cause that and how to fix it?
The spark plug should not come out if it is the proper application spark plug with the correct torque. Sounds as if the plug hole may have damaged/stripped threads which can lead to a costly repair. There is an alternative repair for this without removing the cylinder head. A Heli-coil can be installed into the damaged plug hole. If installed correctly, this repair can last the life of the vehicle at a fraction of the cost
What are the spark plug torque Specs on a 95 Honda Civic LX 1.5 liter.
Torque Chart - E3 Spark Plugs
e3sparkplugs.com/torque-chart/
The table below lists the torquing specifications for most spark plugs being installed in either cast iron or aluminum cylinder heads. Torque values assume clean, dry threads.
Tech Specs - Spark Plug Cross Reference, Torque ... - Autolite
How do I replace the spark plugs?
This requires a certain amount of mechanical skills and knowledge of how to use a torque wrench properly. To begin the process know that the spark plugs are recessed deep in the valve cover. Follow the high tension 8mm wires from their individual coil-paks directly to the respective plug and carefully remove. Now using a 5/ 8" deep well plug socket and an 8-10 extension carefully remove the plugs. Install new plugs (spec per mfg.) I like the iridium then platinum, but check to ensure gap is correct before installing the new plugs. Now take plug and insert into plug socket then carefully lower into recess until you contact threads lightly. Rotate plug clockwise with very little pressure keeping plug socket 90 degrees until you get proper thread engagement. Continue installation of each plug then torque to spec, and reinstall all wires.
CHANGING SPARK PLUGS. WHAT IS CORRECT GAP? WHAT IS
To change plugs you need to remove the coil first. This engine has a coil for each plug.The plug is way down in the head. Use a deep well socket and an extension to remove the plug.Blow out the area around the plug with an air compressor before you remove the plug to keep debris out of the engine. The plug gap is .052 to .056 and the torque spec is 15 pound feet or 177 pound inches. Use some anti-seize on the plugs
How do I replace the spark plugs on the 2.4 L Sonata2003
Use the same specification, the thread size and replace carefully using a correct torque when you install the spark plug..
1helpful
Spark plug torque for honda civic si?
Spark Plug Type NGK: PFR6F-11 DENSO: PKJ20CR-M11 Gap 1.0 - 1.1 mm (0.039 - 0.043 in) 1.3 mm (0.051 in) Torque 18 Nm (13 lb ft)
1helpful
How do I change the spark plugs?
Engine off
Remove one spark plug wire / using correct size spark plug wrench with / rubber boot designed for spark plugs (deep well socket with rubber boot) remove (1) spark plug / gap new replacement spark plug to specs / install replacement spark plug by hand into head of engine /finger tight /using spark plug socket and rachet finish tighting spark plug / tighten just beyond snug being careful to not over tighten and breaking spark plug ..if in doubt about the proper tighting consult motor manual for torque specs. use torque specs in conjunction with appropiate torque wrench . Re-install removed spark plug wire ...proceed to remaining spark plugs doing one at a time until completed.
2helpful
2answers
How to replace sparl plugs on a Jeep Cherokee?
Hello, I hope this info helps...(subytech1)...REMOVAL
In this engine, each individual spark plug is located under each ignition coil.
  1. Prior to removing spark plug, spray compressed air around base ofignition coil at cylinder head. This will help prevent foreign materialfrom entering combustion chamber.
  2. On this engine each individual ignition coil must be removedto gain access to each spark plug. Refer to Ignition CoilRemoval/Installation.
  3. Check condition of coil O-ring and replace as necessary.
  1. Inspect spark plug condition. Refer to Spark Plug Conditions.
CLEANING
Theplugs may be cleaned using commercially available spark plug cleaningequipment. After cleaning, file center electrode flat with a smallpoint file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean sparkplugs. Metallic deposits will remain on spark plug insulator and willcause plug misfire.
ADJUSTMENT
Setting Spark Plug Gap - Typical
Check spark plug gap with a gap gauge tool. If the gap is not correct,adjust it by bending ground electrode. Never attempt to adjust gap bybending center electrode.
INSTALLATION
CAUTION: This engine is equipped with copper core groundelectrode spark plugs. They must be replaced with the same type/numberspark plug as the original. If another spark plug is substituted,pre-ignition will result.
Special care should be taken when installing spark plugs into cylinderhead spark plug wells. Be sure plugs do not drop into plug wells asground straps may be bent resulting in a change in plug gap, orelectrodes can be damaged.
Always tighten spark plugs to specified torque. Over tightening cancause distortion resulting in a change in spark plug gap or a crackedporcelain insulator.
  1. Start spark plug into cylinder head by hand to avoid cross threading.
  2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  3. Before installing coil(s), check condition of coil O-ring andreplace as necessary. To aid in coil installation, apply silicone tocoil O-ring.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
2answers
How to change spark plugs on 2 lt 4 cylinder chevy tracker
My spark plugs are on the top of the motor, take off the individual coil then pull up - this is the wire to the plug. Stick in the wrench and take out I have a 99 tracker 2.0 liter
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
