E-Machines eMachines T3830 PC Desktop Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get compact disc on computer to open with a
Can't get compact disc on computer to open with a paper clip, also will not play or connect to any disk I insert.
Anonymous
Level 2:
Scholar:
  • Expert 100 Answers
  • Posted on Jan 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
100
Questions
0
Helped
18740
Points
283
Ok, the circuit board in it is bad so the opening mechanism. Sorry, but it is time to get a new one. You can find great deals online (personally I use newegg.com) for around 25 to 30 dollars on a decent dvd/cd combo.You should check the motherboard connectors and see if you can upgrade to something SATA instead of current PATA connector. Good luck.
2answers
My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
How do I open the drawer section on a Teac PD860 Compact Disc Player? I try depressing the open/close button on the front of the console and the drawer is not responding.
On the front of the tray there is usually a small hole, this is for opening when faulty.
Use something like a paper clip straightened out to push against the bar inside
How do I open disc door manually
on the front you should see a very small pin hole put a paper clip into this it should open
How do I remove the back of my Gateway ZX6971-UR30P. I have a cd stuck in the disc drive and the door won't open.
Have you tried to use a straightened out paper clip to eject the disc. You should see a small hole next to the eject button on the disc drive, just push the paper clip in that and the drive door should open.
My hp pavilion dv6-3025dx disc tray is jammed.
bad drive
replace it
or remove it, and service it.
things do break, and when that happens we replace them.
Disc draw will not open
Manually eject the disc tray
  1. Disconnect the power cord and any other cables connected to the console.
  2. Uncoil a paper clip.
  3. Position the console horizontally, as you would position a DVD player.
  4. Find the yellow sticker behind the vents on the left side of the console.
  5. Insert the straight end of the paper clip into the eject hole which is located just above the yellow sticker (as shown in the picture below).
  6. The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note If a disc is in the tray, make sure that it is not sticky and does not have a label that might prevent the tray from opening again in the future.
If you cannot get the disc tray to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
  1. Unplug the power and A/V cables from the back of your console.
  2. Position your console horizontally, as you would position a DVD player.
  3. While holding your console firmly, push the faceplate away from the console with your thumbs.
    Note You will need to use some force to remove the faceplate.
  1. Uncoil a paper clip.
  2. If your console has holes below the right side of the disc drive, insert the straight end of the paper clip into the hole as shown in the picture below.
    If your console does not have the holes pictured below, skip to step 5.
  3. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
  4. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9. If the disc tray does not open, try the next step.
  5. Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
  6. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
    Note Make sure you are pushing the gear mechanism and not the metal plate.
  7. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9.
  8. If the disc drive is still stuck closed, insert the paper clip into the adjacent hole (to the right) and push again. If you're successful, the disc tray will pop out slightly.
  9. Now plug the power cord into the back of the console. Press the eject button to open and close disc drive. If the disc drive works properly, reattach the console faceplate.
If you cannot get the disc drive to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Xbox SupportPlease visit the following website for information about how to contact Xbox Support: support.xbox.com/pages/contact-us.aspx
I am not sure what plugs to plug into the compact disc, dvd ram/r, floppy disc, and hard drive. Had a computer wiz change plugs around, now my compact disc won't play any disc, and I have no sound on...
disk drives usually have two main plugs, one for power and the other is a multplug for system communication. power is small with only one connecter. the other multi connecters in the plug. they only fit one way in drives. Just match them up. Power/multi are linked in pairs so that you know which go to any one drive. there are at least two pairs in a desktop. if its a laptop only one pair and you have to take it apart to get at wiring. Desktop, just open case panel to access inside.
We have a computer model T3092. The compact disc section wont pen and it has a cd stuck in there. How to open?
Look closely at the front of the drive. There is a small hole, usually right under the slot door. Get a paper clip and unroll it. Push the paper clip straight through the hole. You should be able to feel it when it releases the catch on the drive door.
Hope this helps.
Thanks for using Fixya.
Wayne
I have a kenwood compact hi-fi system xd-751 the 3
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
