Microsoft Xbox Console Logo
Posted on Jan 30, 2008
Black and White Only
After hooking up my Xbox recently, I'm only able to get a black and white picture. Any idea what would make the output appear in black and white only?
  • Anonymous Feb 16, 2008
    hey i'm running on a 32" insignia lcd and just hooked up my xbox and i can only get black an white color. i've tried switching the order of color coded cables with no luck. also, i've noticed my dvd player has been acting funny lately too (in regaurds to color). thanks for your help
    Mase
  • Tommygun 808 May 06, 2009
    same here bat i have a sonwa tv
Jeff
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 01, 2014
 Jeff
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
79591
Points
6
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
333
Points
I'm sure it's the xbox OR the connection settings somehow.
Anonymous
Level 1:
Problem Solver:
  • Contributor 30 Answers
  • Posted on Jan 30, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
30
Questions
0
Helped
7441
Points
64
Try another tv. is it the xbox or the tv?
When hooked up to a x box 360 everything is black and white
change the output on the xbox in system settings > console settings > display from pal to ntsc or ntsc to pal. That is the reason it is showing in black and white
When I hook it up to the TV and set it up as component 1 I only get black and white and no colour.
Are you using component cables (Y=green, Pb=blue, Pr=red, white, and red) ? If so try changing the component cables. If the picture is still coming in in black and white try another device besides that DVD player that has a component output. If a second device is coming in in black and white with a new component cable then it is the television.
Dear Sir My Dvl 919 dvd player component output give black and white images no colour but SVHS have color images.Pls advise Erwin Koh
there are three wires associated with "component output" .. those have to be hooked up to component inputs on your TV .. not to the composite video input .. if you do hook up to composite you will get only a black and white picture .. make sure all three wires are connected correctly then select the proper input in your TV setup ..
Xbox black and white
If you're in the US, then your problem is you're using a PAL system with NTSC games. Also, it may be that the system is outputting in PAL format to an NTSC TV, but I'm actually not sure if TV's are region formatted as well.
3helpful
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
4helpful
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Black and white picture
you have the cables hooked up the wrong way
17helpful
8answers
2answers
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
