broken belt that wont allow insert/eject of dvd; player makes noise as if running but doesn t open....
(More)
broken belt that wont allow insert/eject of dvd; player makes noise as if running but doesn t open. belt is like a rubber band in length and size
Not having the manual for a used Daewoo DVDS151 player, I'm not sure how to hook it to a Toshiba tv....
(More)
Not having the manual for a used Daewoo DVDS151 player, I'm not sure how to hook it to a Toshiba tv. All I want to do is to play dvds. I've also been seeing alot on the internet about passwords and regions, is going to be a problem?
I have set it up once and had to move it so plugged it in again with all the correct cables in the...
(More)
I have set it up once and had to move it so plugged it in again with all the correct cables in the correct sockets and............................. The set up menu will not appear on the screen i am trying to restore default settings thanks
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
