Acer Aspire 3000 Notebook Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My atheros driver for wifi got uninstalled i have an asus laptop is there a free download to get it back so i can get wifi again
Anonymous
Level 2:
Guru:
  • Expert 243 Answers
  • Posted on Dec 30, 2009
Anonymous
Expert
Level 2:
Guru:
Answers
243
Questions
0
Helped
85744
Points
661
Why does acer aspire 5742z 4824 lose internet connection every 20 seconds
HI There,
There are a number of reasons why this could be happening. Unfortunately I do not know whether you are using a wired connection or wifi. I am guessing in these modern days that you are using wifi but I will post a few things that might help anyway.
Try These:
1. If you are using a wire to connect your router (modem) to your computer, change it. Try a different wire (also called a patch cable) and see if that fixes it.
2. Always remain conscious of the fact that you may have a faulty router. Try switching off your router for 30 seconds and then switching it back on again. Wait for it to initialize and see if that helps.
3. Your computer's NIC (Network Interface Card) may have a dmaged or corrupt "driver". Drivers allow the components in your computer to communicate properly. A damaged driver will mean bad or no communication. So here is what to do to check your driver.
a: right click on "computer" or "My Computer" in the start menu.
b: From the menu that appears, choose MANAGE
c: From the subsequent box that appears choose "Device Manager" in the left side panel.
d: A list of all the devices attached to your computer will show in the large window. Do any of them show a tiny exclamation mark with a yellow background? Whether they do or not, search for the entry in the list that says "Network Adapters" - Click the little triangle beside it.
e: Right click on the first entry and from the menu that appears, choose Uninstall (left click). Wait for the computer to do a little bit of processing. The list may refresh a number of times and the item you just uninstalled may disappear from the list. This is normal and good.
f: Do the same procedure for the next item in the list under the heading "Network Adapters" until all of the Network Adapters have been UNINSTALLED.
g: Restart your computer, with the internet cable connected (If you are using an internet cable). If you are using wifi, ensure it is enabled before restart. -
h: On re starting, your computer will find the items you just uninstalled and will automatically RE-INSTALL them. By doing this, your computer might fix the problem by loading a good driver (in case the old driver was bad).
i: Try your internet after around ten minutes. see if the problem is fixed.
NEXT SOLUTION:
4. Are there other Routers nearby? Do you live in a block of flats or a busy thoroughfare where there are lots of internet connections showing on your wifi list? If so, then it is possible that another router nearby has the same "Channel" as your router and your WiFi card is getting confused as to which router to connect to. - You need to change your Router's WiFi channel. To do this:
Check out these Web pages:
a: http://www.pcadvisor.co.uk/how-to/network-wifi/3325316/how-change-wi-fi-channel/
OR
b:
http://www.metageek.net/forums/showthread.php?6379-How-To-Change-the-Channel-of-Your-Wireless-Network
NEXT SOLUTION:
5. You may need to download another driver for your Network Card on your laptop.
a: Download this driver and install it (double click on it)
http://www.getdriver.com/download/3050/broadcom-lan-driver-14-0-1-0-10-8-mb-acer-aspire-5742z-driver-windows-7-x86/#.U5Aq4rHIytM
b: Also Download this driver and install it... http://www.getdriver.com/download/3071/atheros-wireless-lan-driver-9-0-0-202-9-2-mb-acer-aspire-5742z-driver-windows-7-x86/#.U5ArU7HIytM
c: Finally, Download this driver and install it...
NOTE: Driver B and C above are both for your Wireless Card. One is for a WiFi card made by Atheros and the other is for a card made by Broadcom. Your Laptop does NOT have both cards in it, but I do not know which one it does have so download both. It is possible that on installing, one of the drivers may fail (as the WiFi card for that driver is not in your laptop). in that case, install the other one.
"A" above is for your Network connection when using a cable (non-WiFi). This should be installed to ensure your cabled internet continues to run smoothly.
I am afraid that Is all I have for now. As I always do, I advise you to always use extreme patience when dealing with computer problems. Sometimes your computer looks like it is doing nothing when it actually is processing. But don't grow a beard waiting like.
Hope some of these help.
1helpful
W7 : Asus N53SV Atheros AR9285 network adaptor died after a few days. fn wireless doesnt work, and the hard wifi switch is turned on. However the led indicator is not flashing at all. And of course...
Atheros AR9285 Wireless Network Adapter
Driver is only here
First download for your brand
After you start installation, I think it's everything on RUSSIAN
Very first window you should choose
first upper one - that means English
ENJOY.
P.S. Don't go here http://www.atheros.cz - it's scam.
Wifi notworking
usual problem that I have experienced is the updated drivers windows installs don't work. uninstall them and get the latest drivers for your wifi adapter from the realtek/atheros website, or get linux - it just works (and it's free).
4helpful
2answers
Wireless driver has a problem! were can i download Atheros AR5BXB63 for Asus Pc Eee.
Please download and install the Wireless driver from the following Rapidshare link.
Atheros driver download
Hope this will help you. Good luck...:)
Problem installing WLAN card after installing Vista
First rule-of-thumb, don't trust windows updates for drivers. With that being said, you should find out what the chipset of that Atheros card really is. Download a program called Unknown Devices, by Halfdone. Install the program and run it. It will tell you the actual chipset. Then google search that chipset with the words "xp driver" after it. You should also look at the list and see what the bluetooth type is in you laptop. Usually it will be either a Toshiba bluetooth stack, Widcomm, or Microsoft. Then google that with "xp" after it to find the driver for the bluetooth. Install the software and driver and you should be all set.
Let me know if you need more help.
And if this fixed your issue please make sure to leave comments. Thanks.
Unrecognised wireless chip atheros chip on hp
The wireless driver for Dell Inspiron 8500 is Broadcom according to DELL Support.
Check if have wrongly try to install the driver and the atheros chipset name is displayed on the Device Manager.
Uninstall the Wireless Driver (Atheros) and download the driver for your Wireless card from the link below
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_P4_8500&hidos=WW1&hidlang=en&TabIndex=
Note : If you are sure that the chipset is atheros I'm giving you the link  for lastest wireless driver for atheros chipset too.
http://download2.dvd-driver.cz/atheros/drivers/ar5xxx/xp3264-7.7.0.259-whql.zip
Im not able to install atheros driver for wifi on my compaq presario 773tu...wat to do?
www.drivermax.com
visit the above site and download the free driver utility, install and run. it will find all hardware and search for the latest drivers, all for free.
2answers
Wireless network
http://www.zyxware.com/articles/2007/12/01/drivers/compaq-presario-c707tu-laptop-drivers
There you go all associated drivers appear to be linked there
Lx x note rd400
lg xnote rd 400 which i too have the same model with me uses azurewave atheros names wifi card so it needs atheros drivers so u can download it from lg support site or azurewave site
2answers
Driver for wireless acer aspire 3690
google the complete name of the notebook and + driver download
or visit acer's home page... you should get a driver there to download base on your laptop model
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
