laptop model is aspire 5570 Z with a Z zee instead of 2 two
First, BACKUP WHAT YOU WANT!!!!! IT WILL BE GONE WHEN YOU FINISH!!!!! If you cannot get to your files, start in safe mode and collect them. if you cannot get to safe mode. grab a linux live cd, such as knoppix, you can boot a whole linux os from cd without installing and retrieve your files VIRUS FREE!!!!! once you feel you have backed up what you want to keep follow these insructions.
Reboot your computer. As the computer comes on, click the "F2" key on your keyboard. This will activate the BIOS utility screen.
Locate the Acer disk-to-disk recovery system on the first
screen of BIOS and click the box to enable it. This will allow you to
reset the computer without a recovery disk. Save your settings and exit
BIOS per the instructions on the screen.
Restart the computer.
Press "ALT + F10" on your keyboard as soon as the Acer logo appears on the screen.
5
Follow the on-screen instructions to perform a system recovery and reset the computer to the factory default settings.
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3:When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Unlike
your best bet is get ur hands on a windows disk and reinstall windows then download the drivers from the manufacturer site*acer.com* btw make sure u download the drivers before you erase ur computer..seeing as you wont have internet access without your drivers....
Unlike
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
