Acer Aspire One Netbook 8.9" Notebook Logo
Posted on Apr 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to reset it
Hi i was wondering how do you restart the whole thing like wipe the memory clean because i think i have a virus and is going very slow and it doesnt have anywhere to put a disk.
Anonymous
Level 2:
  • Acer Expert 560 Answers
  • Posted on Oct 08, 2012
Anonymous
Acer Expert
Level 2:
Answers
560
Questions
Helped
587791
Points
670
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
electronic & computer repair& servicre
Level 3:
  • Acer Master 12,061 Answers
  • Posted on Apr 04, 2010
Acer Master
Level 3:
Answers
12061
Questions
0
Helped
4007195
Points
36390
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
1helpful
My samsung gt-s5300 keeps switching over into a vibrate mode and then the whole phone freezes until i take the battery out and restarts it.It only works for a short while and does the same thing.Is it
Use this method to hard reset your Samsung Galaxy Pocket S5300 phone: Enter *2767*3855# , or use volume up + power + home and wipe data
good luck
Mr Difallah walid
1helpful
My cell get hanged and turned restart continously
Hello:::::::
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Jan 17, 2013 • Cell Phones
It automatically restarts sometimes and it resets the whole device to factory setting.
mY Dear:
First:
Secend Option:
*#7370# or *#7780#
Very Best Solution:
9helpful
4answers
Why does my samsung corby 2 keeps on restarting?
i want to master reset it but i cant open it
2answers
Need to reset my acer computer to factory settings.
Hi! Try system restore first and check if that will remove the virus but if not then you can reset the machine to factory defaults by pressing ALT+F10 during start up or when the acer logo appears on your screen.Follow the prompts and you should be able to reset the computer to factory image.Make sure you back up important files because it will wipe the system clean.hope this helps...
SonyEricsson w 700i
  • The thing is that you can't get a virus on your W700i.
  • The problems your describing are ones I've seen before, it sounds like there is something wrong with the memory stick being used, and possibly the phones own internal memory (can't be sure as I don't know where all the files are being saved to).
  • Try this first of all, wipe the memory stick blank if you can and the same for the phone media memory (your images, pictures, etc, etc) if you can. See if that works.
  • If that doesn't work, then you can try a hard reset, which will wipe your phone completely. Failing that it'll need to go in for repair.
Please rate for my solution .... Thank you
1helpful
2answers
"Operation Failed!"
master reset will not work.. They say you have to Flash your phone. I think it mean you'll have to wipe the whole operating sytem of your phone and replace it with a new one..
2answers
Got a virus want to set it to factory or wipe the whole thing and start fresh. HELP!!!
well 2 things you can do,
When starting up you can push F8 or F2 so you get in the safe mode.
Run virus scanner from there.
It can also be a faulty HD. Which is a little more expensive to change out. Hope on the safe mode solution.
SanDisk Sansa E260: How do I reset the WHOLE thing?
Recommend that U get (purchase) a good anti-virus like Shield Deluxe to protect Ur system. Use Msconfig to cleanup Ur startup and use disk clean then defrag. Clean and defrag often, once a week. And keep in mind that itunes is a Mac program and nothing runs perfect on windows.
1helpful
2answers
N70
You can perform a master reset of the phone to get rid of the virus. Make sure you back up everything since this wipes out everything. Here is the code for the reset:
*#7370#
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
