I looked for a bypass for your models but none listed . just remove the cartridge. this should work. you could also by pass the filter by connection the two lines lik they do on water softners. . valve or connector in back .. now a word to the wise . they do not recommend hooking the frig up to r. systems as the do not produce enough pressure to the main valve to shut if off ( sometimes ) thus causing a flood . if you do use 3/8 or better line size . this will help .. **** . hope this helped . mm
