Volvo has puff of blue smoke on startup when engine is warm
If you have a turbo, a shaft seal may be leaking some oil. Otherwise, the valve seals may be hard or worn enough to pass some oil during 'off' time. As long as it smokes only at startup, there is probably little to worry about until it begins smoking all of the time--then it will be time to replace the leaking seals which can be done without removing the heads. You might try a seal-softener additive in the oil or use 'high mileage' oil which contains seal softener. It also helps loosen sticking rings as well. Hope this helps.
Testimonial: "Thank you - was worried that may be major repairs"
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
These
details will help.
Thanks.
