MF750-- Have installed 4 512 PNY Gamer memory chips @800. When booting up the machine, the ram shows up as 677. I have already tried flashing the bios to the latest version, but to no avail. Forcing the ram into 800 via the bios config does nothing either, except cause the amount and speed of the ram to show up in bold white on boot up.
Thanks for any help
I have the same MoBo that you speak of. Have you overclocked any portion of the settings under the advanced tab where you found the memory speed? Overclocking affects all aspects of the system. You may want to download CPUZ and check the settings from there. Also, you should download NVIDIA's Performance Control Panel so that you can control the speeds of your system more easily. Good luck,
- teay11
Try to update the BIOS ! ... it may correct the problem ...
http://www.epox.com.tw/eng/support.php?ps=424&type=1
when using only one module at a time, doest it work on the correct speed 800Mhz ?!
the system will be working on the BIOS declared parameters, at 677 !
Also read all the indications in the motherboard user manual, regarding memory (supported brands, speed, slot allocation .... )
thought i hope the BIOS update will do the trick ...tell me if it worked ...
Setup new bios and remove your old battrey ..........
Yes all memory mods are 800.
KriHard, What do youmean setup new bios? I have already flashed it and tried removing the battery, not avail, then reflashed again, but still same problem.
Maybe a better question is, will by bios reporting the speed as 677 limit the memory to that speed, or wil it run as 800 regardless?
BTw, I incorrectly stated the motherboard. It is a epox mf570, not a 750
AS I stated earlier, I already flashed the bios to the latest version.
On your advice, I tried using only one stick, but the bios still reports it as 677.
All Indications on the motherboard manual say it does support 800.
I also have tried contacting Epox, but thier technical support dept. stated they are closed.
Thanks for trying cosisf!
are all memory modules 800Mhz ?! if not they will work at the speed of the slowest one ....
