Troubleshooting & Support
Hot Topics:
- drivers
- driver download
- boot CD
- driver
- Bios beep
- ad1980 adi...
- power
- cpu frequency
- reset
- manual
- download...
- download...
- cmos
- bios
- usb
- drive
- AC97
- HDD LED
- jumper settings
- beep
- battery
- cpu external...
- intrusion
- connected cpu...
- driver soundmax
- bios reset...
- te driver
- layout
- MANUAL DOWNLOAD
- problems
- View All »
Problems & Solutions
I just replaced a 2.53
Did you reset the cmos jumper pins on the board close to the battery or cmos chip. That is a 478 socket board. ASUS is all i use.
my pc partially doesnt work. when i press the
I would start with a new bios battery first. There is absolutely no need to reformat a hard drive for a bios issue. I would also hold off on...
i installed 2GB ram pc doesnt start, i mean it
Will it actually recognise 2GB of ram? That could be your problem. Mine will only recognise 1.5GB. If I put in 2GB, it causes problems. More...
Will 800MHz P4 3GHz chip work on a Motherboard...
Hi There, Yes it will work but you won't get the response which you would exepect. I wouldn't... Regards, Philip
HELP ME
I've been wondering that myself. The SoundMax Drivers on Asus' website (usa.asus.com) start an install, but don't actually work...
sound problem
I believ that the possibilities are only two. First, you have improperly or mistakenly installed the drivers, whether updated or not. I...
drivers for using with vista
http://support.asus.com/download/download.aspx?modelname=P4PE-X&SLanguage=en-us Asus motherboard, no vista drivers for components...
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations. Since you know one bank of memory works fine in a certain slot. Now try the...
P4PE-X Motherboard bus speed
JAAh, I have the same motherboard and did a little reading. The chipset on these motherboards was not really designed for...
P4PE-XTE and new CPUs
Hey paul you're doing all the work :) I wish ASUS would say something :/ Eventually someone will buy a Celeron D and post on this...
all drivers sound etc
Hi tonylig The on board LAN should be a Broadcom and you could be lucky with this download , assuming you have access to the Internet with...
hello.. i have a asus
this will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply...
sound and audio card
Your board, as I'm sure you already know, has no on board graphics and also, unfortunately came with sound software that is no longer in...
aggiornamento bios
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4PE-X%2fTE&os=&hashedid=Edv9I9xTTboIppD3 here?
Unsolved Problems
Ñ?...
Ñ? менÑ...
i dont have driver for
i dont have driver for mother board
can i get driver for
can i get driver for mother board asus P4PE-X
vladek821@gmail>com
vladek821@gmail>com
HOW CAN I GET MOTHER
HOW CAN I GET MOTHER BOARD SOFTWARE OF ASUS P4GE MX ACPI BIOS REVISION 1005
motherboard not firing up
motherboard not firing up, or intermittantly but not even showing startup screen and no beep error codes - Does it seem...
Asus P4PE Power Problem
I have an Asus P4PE motherboard and I am obviously getting power to the board because the green light on the board comes...
P4pe-x mother video issus
it boots up but dosnt show any video output, ive tryed every video card i got from pci to the vga
Upload a manual for ASUS P4PE-X Motherboard
Specifications
TopKey Features
Full Product Name:ASUS P4PE-X Motherboard
Form Factor:ATX
Compatibility:PC
Chipset:Intel 845PE
Compatible Processors:Intel Pentium 4
Front Side Bus Speed:800 MHz
Processor
Max supported CPUs qty:1
Memory
Max Supported RAM:2 GB
Other Features
Chassis Type:1
Dimensions
Depth:9.02 in.
Width:12.02 in.
What's your problem?
Fix-O-Meter
9,832
9,832 people have viewed this product
- 51 people asked about this product.
- 33 people found solutions for this product.
- 0 people have added this product. Be the first!
Break BIOS...
How to Download...
Computer POST...
