For
car not changing gears it can be shifter assembly issue, or it can also be
transmission issue. Get the shifter assembly inspected with ignition OFF.
For
more troubleshooting, I suggest you to get the Following help link checked, its
complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND
FLUID LEAKING ISSUES
Transmission
gear assembly and transmission needs inspection. Also check the transmission
fluid level. Also is the fluid getting leaked or its low.
There
are few very helpful links with solutions to troubleshoot this problem.
I
suggest you to refer these links.
Click
the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These
details will help.
Thanks.
Transmission
There
I
Click
TRANSMISSION REPLACING AND
TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
These
details will help.
Thanks.
These details will help.
Thanks.
Transmission
There
are few very helpful links with solutions to troubleshoot these problem.
I
Click
2000 Toyota Camry:
not operating?
leaking?
windstar?
These
details will help.
Thanks.
