This can happen sometimes with a lot of smartphones when the battery is completely empty. This is usually solved by letting the phone charge for a whole 24h. I hope this works for you!
Good luck! And please, if you do find this answer helpful give it thumbs up :)
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died. To fix it, kick start the charging process. Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process. If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers. Hope it helps? Success.
Hi, The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
The battery needs to be revived when it is completely drained or when it is dead because the phone will not be able to charge it. For instructions on how to revive battery, check it here.
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
I would check the battery, it could just be a dead battery. The phone will look like it's charging but the battery isn't. I would check with your carrier and see if they can help you figure out if it's the battery or the phone.
I have a cellphone virus that i want to remove pls assist!
