20 Most Recent
Motorola Mobility E398 Cellular Phone Questions & Answers
Can't be delete picture in phone memory
solution #1 ---click on the picture..options settings edit/save/manage..try manage delete
only if you really must (if you accidentally click on the wrong folder you can really damage your cell)
solutions #2 ---connect to pc via usb cable go to my computer see phone open it you should see three folders (they might be hidden) but you are looking for data folder..see picture delete it
7/10/2010 6:32:15 AM •
Motorola...
Answered
on Jul 10, 2010
Hot batteries
The phones get hot when the internal transmitter turns up the power in the attempt to maintaain communication with the cell tower. This occurs EVEN if phone is not being used as the phone has to "call home" to let the tower know that it is available if called.
Hence warmth in weak signal areas is somewhat normal.
6/30/2010 3:38:37 AM •
Motorola...
Answered
on Jun 30, 2010
Pasword unlock
try to enter the default code for motorola 000000 ,if not works you need to go cellphone shop and unlocked it using smartclip dongle..thanks
6/12/2010 6:31:07 AM •
Motorola...
Answered
on Jun 12, 2010
How can i connect to the iternet
If you want to connect to internet on your phone then please activate GPRS services on your phone and then get GPRS settings on your phone from your service provider.
5/24/2010 7:52:14 PM •
Motorola...
Answered
on May 24, 2010
Motorola e398 keypad doesnt respond
hedset
I have a lot of problems. keypack the problem as one that would help
please send an email message to me solehin.azrain @ yahoo.com or
solehin.azrain9 @ gmail.com
4/13/2010 7:30:20 AM •
Motorola...
Answered
on Apr 13, 2010
Themes
here's the perfect solution :)
Go to
www.zedge.net
insert your mobile type motorola E398
and enjoy millions and millions of BEAUTIFUL themes
Hope i helped :)
2/2/2010 2:27:25 PM •
Motorola...
Answered
on Feb 02, 2010
I have a duplicate charger and duplicate battery
yes u can have a new orignal battery and charger.......
and my advice to u is to must buy orignal battery and charger as i had the same problem with my NOKIA E52....but now i m using my cellphone
1/29/2010 10:34:01 AM •
Motorola...
Answered
on Jan 29, 2010
E398 water damage
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
1/17/2010 5:29:13 AM •
Motorola...
Answered
on Jan 17, 2010
