Samsung SGH-G600 Cellular Phone Logo
Posted on Dec 19, 2009
How do u turn on voicemail - Samsung SGH-G600 Cellular Phone
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Dec 19, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
5044
Points
60
You will most likely have to call your provider and have them reset or enable your voice mail. I had my voice mail just stop working one day after no problems for over 5 yrs. Just call the 3 digit carrier # and let the tech. dept. know what's going on and they should take it from there.
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
My provider says I need to turn off voice mail on my phone so they can provide vm service. How do I turn it off?
  1. Dial your own phone number and wait for your voicemail greeting to start playing.
  2. During the greeting, press the * key (star key) to interrupt the greeting.
  3. Enter your voicemail password or PIN if prompted.
  4. Follow the voice prompts to access the main menu for your voicemail.
  5. Navigate to the option to turn off voicemail (sometimes referred to as deactivating voicemail).
  6. Follow the prompts to confirm that you want to turn off voicemail.
Note: If you're unable to turn off voicemail through these steps, or if you need further assistance, contact your service provider for specific instructions.
If you still want to access your voicemail messages, you can do so by calling your voicemail service directly. On most phones, this can be done by dialing *98 or by pressing and holding the 1 key on your phone's dial pad. You may also be able to access your voicemail through the phone's app or by calling your service provider's customer support line.
My ZTE phone goes to voicemail and never rings why?
It is either not registered on the cell network or is out of signal and defaults to voicemail. Or Voicemail has been enabled in error. find out from your local phone shop which code to enter to turn voicemail off. ( my provider uses 1261 on giffgaff to turn voicemail on and 1262 to turn it off.) It depends on the network as to what code you need to use.
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
1helpful
How to turn off voicemail on samsung s4
To turn on voicemail on s4 go to settings then open voicemail settings. Here you can change the voicemail settings
Nov 16, 2013 • Cell Phones
Turn on voicemail indicator on my vtech
On most VTech phones the voicemail indicator turns on when someone leaves a message on the voicemail system offered by your phone company. Many phone companies have such a system, which takes messages when your phone is busy. You'll have to contact your phone company for instructions on accessing their voicemail system.
2answers
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 • Cell Phones
Turning on my voicemail
Depending on the carrier it can be a little bit different. Basically you need to dial the voicemail number from your cell, most commonly 123. After this an automated machine will guide you through the setup.
Hope this helps,
Joe
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 • Cell Phones
3helpful
Turning off answering machine
Hi
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
