I believe you need to connect you MP3 player to Computer using USB. Then only you can delete your songs. Many MP3 players does not allow you delete songs or any media when they are operated. :)
You can reformat it by first resetting it then plugging it into your computer. The method of doing this on a PC is to right click the mp3 player under (My) Computer and then choosing reformat... Make sure you backup all your music and the system files first. Good luck!
The MP715 uses avi format to playback.
From the support internet site of Coby you're able to download Coby Media Manager.
You can use this manager for converting and transferring data.
How to get the manager:
Enter cobyusa.com in the address bar of Internet Explorer.
Next select Support in the page top.
From the support site select Manager fix for the MP822: It is the complete software program.
Follow up the steps to download and install Coby Media Manager, matching your operating system.
After installation, run the Manager.
Select Tools > Device Manager... in the page top of the program.
From Devices List, select MP715. Add >> OK , to setup the selected player as your Favorite device.
In Device configuration you can setup the synchronization and see the output file formats for the selected model.
Use the Help [F1] function, for how to work with the Manager.
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
ok plug the mp3 in the pc and select open files download your songs and they will save in my documents then all you will have to do is drag them from one file to the other
Be sure the movies are in one of the following formats, these are the only formats that will play on your MP3 player: Supported formats: MP3, WMA, OGG, WMV, FLV, AVI, JPG, BMP, GIF, TXT according to my research.
You can see this information at this website: http://www.sonicelectronix.com/item_14951_Coby+MP715-2G.html
You can download a free format converter at the following website:
http://formatoz.com/
Good Luck, I hope this helps Please do not forget to rate me, Thank You
plug it in and open my computer.there should be a drive with click it to add or remove objects.if it won't delete then try formating the mp3.before you format get all of the song,ect off. if you need help formatting i will send instructions by email.my email account is [email protected]
