Rca Model number R52Wh73 Tv is not acting right when i tried to turn it on the green light comes on then after a second it shuts right back off any one out here can you please help me cause when i turn my cable box on then i turn on the tv i can hear the sound coming up then after a second it shuts back off and you have to repeat the steps any help
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Capacitors 97cents, They are in the start up circuit and on deflection board bottom left side board has FBT flyback transfomer,they are up on front of board. Most of them where Green with Gold writing on them and cp150 usually is puffed up on top. Call Mats Electronics for capacitors 1-800-628-1118 use 25v instead of 16v on cp150 2200uf 25v other 2 are 220uf 35v
LOOK at cp 150, most of the time they are puffed up on top like a flower fixing to open up capacitors should be Flat as a board on top! Charge for repair in shop for same Job $275.00 32yrs in Repair what would you Think! Labor charges here start at $190.00 I cant say that I am 100% positive because Im not There to Look at the Capacitors thats Why I told you to Look! But This has been The Most common Problem those sets Have. If you had a Blowed Fuse set would not come on at ALL. Also resolder all the pinns on FBT flyback Transfomer.Its common knowledge Too. 9 times out of 10 thats what is Bad capacitors.
Can you please Tell me What are the Capacitors And what do they Do and also can you let me know how Much they cost and will This be something Very Expensive.
Ok so the Capacitors is the Reason why when i Turn my Tv on It shuts back off so this is like a Fuse or something So are you Postive that this is what is wrong so when the Tech comes out tha's something that i can have him check for just looking for the Answer to solve my Problem
