Cleaning my files, accidentally lost drivers for my Pioneer DVD-ROM DVD-117R, also Pioneer DVD-RW DVR-104....driver 5.1.2535.0
System restore could not take me back far enough, and cannot load Recovery...
BAD DVD
Windows 7
To resolve this problem on a computer that is running Windows 7, use the Hardware and Devices troubleshooter. For more information about how to open this troubleshooter in Windows 7, visit the following Microsoft Web site:
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
Back to the top
Windows Vista
Click Start, and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
Exit Registry Editor.
Restart the computer.
Now go to the "Did this fix the problem?" section.
Back to the top
Windows XP
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
Back to the top
Windows 7
Click Start, click Computer, and then see whether the drive is listed.
Windows Vista
Windows XP
Click Start, click My Computer, and then see whether the drive is listed.
Back to the top
Is the drive listed?
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
iTunes software by Apple
Nero software by Nero Inc
Roxio Creator software by Sonic Solutions
Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD, please see the "Next steps" section.
If the drive is not listed, remove and reinstall the existing drivers.
Back to the top
Remove and reinstall drivers
If the drive is not listed, remove and reinstall the existing drivers. To do this, follow these steps:
Windows 7
Click Start, and then click Control Panel.
Click System and Security, click System, and then click Device Manager.
Note If Control Panel is in Classic View, double-click System, and then click Device Manager.
In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
When you are prompted to confirm that you want to remove the device, click OK.
After the computer restarts, the drivers will be automatically installed
Windows Vista
Click System and Maintenance, click System, and then click Device Manager.
After the computer restarts, the drivers will be automatically installed.
Windows XP
Click System and Maintenance, and then click System,
On the Hardware tab, click Device Manager. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
See if reinstalling the drivers fixed the problem.
Now try to play or access a CD or DVD.
If you cannot play or access a CD or DVD, please see the "Next steps" section.
Back to the top
Next steps
If this method did not help you, you might want to use the Microsoft Customer Support Services Web site to find other solutions. Some services that the Microsoft Customer Support Services Web site provides include the following:
Searchable Knowledge Base: Search technical support information and self-help tools for Microsoft products.
Solution Centers: View product-specific frequently asked questions and support highlights.
Microsoft Product Support Newsgroups: Contact counterparts, peers, and Microsoft Most Valuable Professionals (MVPs).
Other Support Options: Use the Web to ask a question, to contact Microsoft Customer Support Services, or to provide feedback.
If you continue to have questions after you use these Microsoft Web sites, or if you cannot find a solution on the Microsoft Support Services Web site, click the following link to contact Support:
http://support.microsoft.com/contactus
Back to the top
More information
This issue may have occurred after one of the following situations:
You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
You install or uninstall CD or DVD recording programs.
You uninstall Microsoft Digital Image.
You may see one of the following error messages:
One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
Error message 1
The device is not working properly because Windows cannot load the drivers required for this device (Code 31).
Error message 2
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
Error message 3
Your registry might be corrupted. (Code 19)
An "error code 39" error message.
A message that resembles the following appears in the notification area:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
yes i am sure. I was using it.
