Compaq Presario M2000 Notebook Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get rid of the vertical line on my screen
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Answers
458
Questions
Helped
242808
Points
1345
You Can't.. The Vertical Line Is A Short/Failure In The Screens Circuit Board..
The Screen Will Need To Be Replaced To Correct Issue.
Why do i have a green line on my tv
Vertical green lines on tv screen - Samsung 60" LED TV ... - iFixit
https://www.ifixit.com > Answers > View > Vertical+gre...
Jul 5, 2018 · 6 answers
Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there ...
How remove colored vertical lines all over screen of my LED ...
Dec 9, 2015
I have horizontal lines on part of my TV screen. - Sony Television
Dec 18, 2017
SOLVED: Why there's a green line - Samsung Television - iFixit
Aug 6, 2016
F-Series Vertical Green Line - Samsung Television - iFixit
Mar 8, 2018
More results from www.ifixit.com
Why does my TV have green lines on the screen? - Quora
https://www.quora.com > Why-does-my-TV-have-gree...
Sept 17, 2016 - With the green always on, it suggests that the cable the connects to the panel may have a bad line. Whether or not the cable has moved a bit to cause a short ...
6 answers · 10 votes: If its the same on every channel it means your TV is broke. I'm not tying to be a wise guy ...
There is a very thin green line going down my TV screen ...
Jan 3, 2021
How can I repair a TV with vertical lines on the ...
Dec 21, 2016
What causes a horizontal line on a flat screen TV? - Quora
Jul 25, 2018
What does it mean if a Samsung TV starts displaying ...
Jan 29, 2016
More results from www.quora.com
How to Get Rid of a Thin Green Line on an LCD - ItStillWorks
https://itstillworks.com > rid-thin-green-line-lcd-36231
A line of solid color indicates stuck pixels within your LCD. ... Your LCD produces specific colors and images by altering the colors of the thousands of tiny ...
5 tips to get rid of stripes on your TV screen - Coolblue
https://www.coolblue.be > advice > tips-for-removing-li...
Dec 18, 2021 - You can read 5 tips on removing horizontal or vertical lines on your TV screen here.
Vertical green line on Samsung LED TV : r/hometheater - Reddit
https://www.reddit.com > hometheater > comments > ve...
Apr 18, 2016 - It is most likely dead pixels within the monitor itself. You can try a stuck pixel video on YouTube that will flash colors or even give you a ...
Tv fell off stand. tv has vertical rainbow lines on right side of screen. how do I get rid of the lines?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
Vertical scan lines
It sounds that there is a loose contact to some connection wires, the flat wires that comes in, and go out the T'Con board. Re-seat all the flat cables and check. http://electronicshelponline.blogspot.com/ Check this link too. It has screen shots to different faulty displays. Pull up older posts and compare with these images to your TVs screen, and make confirm. Remember, vertical lines can be due to a faulty LCD display screen too.
How to get rid of white vertical line on my laptop
may be an bug in the os or driver or hardware damage check it
Have red vertical lines in center of screen from top to bottom
iam also facing same problum,that problum wont start immedietly,when we r watching after 1 hr it will start
I have several verticle lines on my screen, how can I get rid of themm?
Vertical lines on your LCD usually tells you that your screen is failing. You can do a quick verfication by plugging in an external monitor - and if the external monitor looks normal, then that ought to confirm it.
Once you have vertical lines on your screen, there's no way to get rid of them - it's pretty terminal unless you're into repairing microelectronics. For replacement screens, eBay would probably be your best bet.
Vertical lines on my laptop screen
Bad LCD, was it bumped or dropped?
Inexpensive replacement LCD at :
http://www.smartmicrousa.com/
I have used them for years, GREAT customer service.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
White Lines
hi there, you do have a vertical problem, its a resistor with 100k ohms or up at vertical section, next is some capacitor with 100microfarad. try test some parts at vertical section. ty
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
